Well it sounds like the shaft for the high range broke. Hard to tell from here though. If you can pull the shaft out from the trans case much, like more than normal end play it will tell you if it is broke. Like I stated in the other reply you will have to pull the top off. There is an o-ring groove for a seal on the shaft that is where they usually break. that shaft/lever is not cheap from dealer. That is why we went to welding them. We don't even have the o-ring in there anymore. It fits tight and is above the oil level. There is a nut on the other end with a spline for the fork arm to slip onto. Then tighten the nut up. We used to use lock tight on the threads. If you want to talk my number is in the other reply.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
