I have had pretty good luck putting a 3/8ths bolt with flat washers and nut through the guide, the washers just fit the bore in the head , and drive them out with a hammer and a big brass drift. If you buy new replacements, be aware of what they are made out of, originals were cast , some of the new ones now are steel and need to be reamed or bored out to fit the valve stem , and make them sloppy or they will stick when the engine gets hot , they seem to expand more than the originals.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
