I have a Super H with similar issues. After sitting idle for 10 - 11 months it absolutely refuses to start despite good spark, fresh gas, etc. However a squirt of motor oil (or blast of WD-40) into each hole will get it to start right up, then run fine once the smoke clears. And as long as it's started every few weeks afterward it starts easily.
All I can figure is it loses compression due to dry cylinder walls from long periods of sitting. A bit of oil to wet the rings is all it needs to get compression back following a long layoff.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
