Posted by Ed Hotaling on July 06, 2014 at 18:12:18 from (67.240.55.230):
In Reply to: SA Loader Problem posted by Doug Kieta on July 06, 2014 at 15:11:17:
My first thoughts re either the cylinder or the valve. I have had cylinders stat to leak internally when the seal gets worn or the nut holding the piston on the end of the shaft works loose. The valve could be leaking internally as well. If the cylinder is repairable, it is fairly easy (messy, but easy) to open it up and inspect. If it is welded together, you are skunked on that one. The valve would be a bit more of a job.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
