Posted by Brendon-KS on July 07, 2014 at 04:12:52 from (63.245.147.52):
In Reply to: Re: SA Loader Problem posted by Ed Hotaling on July 06, 2014 at 18:12:18:
According to an old sales brochure I have the 1000 was only available with a single-acting lift cylinder. On this kind of cylinder an internal leak basically means an external leak so you should be able to tell if that is the problem unless your loader has been updated with a double-acting cylinder. You could also install a reliable shut-off valve in the hose between the spool valve and cylinder. After raising the loader and shutting the valve note what happens. If the loader stays up, your problem is in the spool valve. If it still creeps down your problem is in the cylinder.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
