Posted by Larry B. 1486 on July 25, 2014 at 12:41:17 from (72.105.171.170):
In Reply to: b450 farmall project posted by deltafarmer on July 24, 2014 at 20:03:59:
I had a British 450 back in the 1970's and early 1980's and then parts were very hard to come by. very few of the internal parts will interchange with the American FARMALL 450. The engine is completely different. Some sheet metal from a super M will fit. Transmission similar to the FARMALL but none will fit. The B450 has a factory 3pt hitch and a differential lock with a glow plug direct start diesel engine. BD 264 if I remember correct. At the same time I owned a SUPER MD and there was no compairison between the two. The B450 would walk away from the SMD rated having the same hp. There was one parted out at a salvage yard not long ago in Mayfield KY. Still might have some parts??? Steve Smith's 270-247-2219. I still have the owners and parts manual for the one I owned.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
