You can use the draft control. It gets to be a little complex and unhandy but will work. To start, put position control lever down to the offset. Do not at this time go past the offset. If your levers are working right you can feel the offset without even looking but so many levers are not adjusted right so hard to tell from here. From offset on down to end of slot is what is called action control. On the lifting cycle, it dumps oil so slower lift, on lowering cycle it blocks return so slower lowering. Now, pull draft control lever all the way. Hitch should lift to near full height(it will not lift quite as high as it will with position control lever). Next, put position control lever fully forward in slot, now push draft control lever forward all the way. Hitch should drop slowly and if you pull position control lever back a little at a time you should be able to control the drop. Like I said, kind of a three handed game but it can be done. Other option is to pull rear cover, block a port inside between draft control and action control valve, install an adjustable external control that you control drop speed from inside cab.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
