Posted by clint s on August 12, 2014 at 10:29:18 from (67.242.45.169):
In Reply to: Dead spot in starter? posted by DaninKansas on August 11, 2014 at 14:42:17:
I bit the bullet and bought a new starter a few years ago because the end cap on mine was cracked and the gear was a bit chewed up. Worked well for two or so years and then all sorts of issues. Now mind you this is not an everyday use machine. Tedded use during hay season send pulling a wagon of wood on the fall. First the brushes wore down to nothing and then intermittent dead spots. Ended up replacing all the internals with the stuff from the old starter. Now it works better than ever. This new stuff has no quality control.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
