Posted by fixerupper on August 13, 2014 at 15:13:37 from (70.198.35.180):
In Reply to: Dead spot in starter? posted by DaninKansas on August 11, 2014 at 14:42:17:
Those older starters were simple creatures. Maybe you could try your hand at fixing it yourself. If you post a few good pictures of the commutator end of the armature and also the brushes after you have it apart a bunch of the guys on this site could give you advice. That old starter is well worth fixing and you have nothing to lose. You can't screw it up THAT bad.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
