Like Gene Said. I will wire wheel them clean and paint them with primer and high temp black paint on the exhaust portion and then mask and paint the 2 lower intake tubes red with the tractor. Essentially the black with burn off over time and the lower will stay red giving you the original look. When doing a restoration the black makes it "pop" and it does last on there for a good while if not used much.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
