Posted by Fudd on September 05, 2014 at 17:55:13 from (63.228.77.157):
Last spring I installed new rear axle seals in my 400. This summer while doing hay and going down a blacktop, the thing rocks back and forth. I removed the whole wheel, tire and rim assembly on one side but on the other side the bolts holding the axle clamp were frozen. I cut them off with a torch and removed the tire/ rim and then the center wheel casting. When I put it back together, I tried my best to have the rim centered on the cast wheel when I tightened the clamp bolts and feel I got it really close. Using a large wrench as a feeler gauge it checks close but not perfect. The other side that I did not have apart checks farther off center. How close do these have to be? I guess I will make up a go/no go gauge to set them real close to being centered to see if that corrects it. It will have to wait untill haying is done so I guess it is a winter project. At least the axle seals don't leak:)
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
