Posted by Joshua Rod on September 15, 2014 at 10:12:17 from (66.188.152.67):
Getting my motor for the Super C wrapped up. The small gear on the end of my distributor is heavily worn, as is the gear/shaft that goes into the governor. I ordered both replacements this morning. How do I get the old distributor gear off? There is a small screw on the side of the distributor that would use a flat-head screwdriver but it is all rounded off. My other thought was through the top, under the distributor cap. Before I start damaging anything else, what is the correct way?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
