Posted by roger hall on September 15, 2014 at 20:52:12 from (74.126.67.106):
In Reply to: Rusty gas tank posted by cubluvn8n on September 15, 2014 at 17:21:07:
i have done a lot of different things now I go streight at the problem ---drain all the fuel--pull out the sediment unit --turn the water hose on it--some sort of spray directional nozzle--catch what comes out in a 5 gal bucket you will be surprised---- put your sediment unit back in--hook the lines up--put 1 gal gas in and drive it a little---drain the bowl a few times -all water will come out
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
