Posted by rustyfarmall on September 16, 2014 at 05:08:05 from (208.126.186.41):
In Reply to: Rusty gas tank posted by cubluvn8n on September 15, 2014 at 17:21:07:
If it is seriously rusty, removing the tank and having it chemically cleaned is the only answer.
If the rust is not all that bad, just leave it alone, make sure the sediment bowl is fully functional, and clean the sediment bowl on a regular basis. Eventually, the rust will have all been flushed into the sediment bowl, you will have cleaned it out, and it will be gone. NO more problems.
THAT is what the sediment bowl was designed to do. Just let it happen.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
