it is very seldom that a set of filed points will not work. that is one thing with points , is that you can always get out of a bind. just carry a point file and feeler guage. sometime just cleaning them is not the answer. you have to actually file both contact points flat to get the pitting flat, which is caused by the condenser. when you see blue burn't contact points that's an indication to replace them. your problem most likely is the condenser needs replacing. check the rotor and cap also. plug a spark plug into a wire and ground it and crank the engine slow and when impulse trips you should have nice blue spark. take notice that impulse must be working also. make sure your plugs are good also.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
