If the 656 were a hydro I would give it the advantage, but since it's a gear drive I would have to go with the 684, all other things being equal.
All the controls on the 684 are much more ergonomically designed, located within easier reach. Everything on the 656 is a stretch, which gets old if you do a lot of shifting.
The 2250 loader is easily removed, while the older IH loaders aren't, so that's a big plus.
If you have to get on and off a lot, the 656 row crop will have you swearing unless you add some steps.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
