Posted by matthies on January 08, 2015 at 07:54:22 from (164.119.51.238):
In Reply to: farmhand f11 loader posted by butch49 on January 07, 2015 at 18:52:05:
Usually just two long bolts and a piece of angle iron, best is to weld a flat strap to the loader frame where it sits in the front channel of the axle housing front side, that way the loader frame doesn't dance around on the axle housing. And maybe make a plate to bolt the side frame of the tractor and the steering bolster together, otherwise the frame engine mount bolts break. chris
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
