Posted by JD Seller on September 17, 2013 at 06:46:01 from (208.126.196.144):
In Reply to: Long 445 hydraulics posted by John Marshall on September 17, 2013 at 05:43:20:
I think that pump is a simple gear pump. If it is there is no simple rebuilding it. The gears and housing both wear. So you would have to machine the housing and replace the gears with bigger ones. A new pump would be cheaper.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
