TD-340 - Loss of power to the tracks
trees
12-14-2007 16:47:57
I have a IH TD-340 and it is startin to lose power to the tracks. I assume the clutch is worn out. Can someone recommend a source for a clutch rebuild kit.
I've been told I have to pull the engine to get to the clutch. True?
trees
12-21-2007 09:41:18
 Re: TD-340 - Loss of power to the tracks in reply to trees, 12-14-2007 16:47:57
CHinNY,
What is you link?
Trees
trees
12-16-2007 15:52:20
 Re: TD-340 - Loss of power to the tracks in reply to hector gemme, 12-14-2007 16:47:57
You nailed it...
Thanks. You saved me a lot of time.
Regards,
Trees
CHinNY
12-19-2007 04:53:22
 Re: TD-340 - Loss of power to the tracks in reply to trees, 12-16-2007 15:52:20
If you need shop parts or operators manuals i sell them email me for my link
Charlie
12-15-2007 05:42:20
To follow up the other comment, check the free play in the steering brake levers. Should be about an inch and a half at the top of the levers. If you don't have any free play, there's good hope that you can just do this easy adjustment. You'll see a lock nut and adjuster where the linkages go into the transmission, sort of under the seat. Tie a steering arm back all the way (essential) and tighten the adjuster, then check free play. Get them both right and now try the machine. A good chance you'll be all set.
CHinNY
12-14-2007 17:15:21
You may want to try adjusting planetary brakes first. I have clutch parts and planetary brakes.
