Re: Super C clutch won’t disengage
old
05-25-2018 13:47:51
Either the throw out bearing or the pressure plate flingers are bad. Had an 8N in the shop this winter that had the throw out bearing lock up on it and that in turn cause the pressure plate finger to be eaten away and the clutch would not release. Guy who owned it said it happened all at once had clutch then no clutch release
keeter84
05-25-2018 14:23:05
 Re: Super C clutch won’t disengage in reply to old, 05-25-2018 13:47:51
So looking in I could see one of the fingers was away from the pressure plate. I tightened the bolt up on the finger and it’s back working. I’m pushed for time and just hand tightened. Seems weird to me though.
old
05-25-2018 14:35:24
 Re: Super C clutch won’t disengage in reply to keeter84, 05-25-2018 14:23:05
Sounds like you may have lost a lock nut. On most that I have seen on any pressure plate the adjustment parts have a lock nut on them. Lock nut comes off and then the finger gets out of adjustment and then that area of the clutch does not release and cause that
keeter84
05-25-2018 17:04:14
 Re: Super C clutch won’t disengage in reply to old, 05-25-2018 14:35:24
On the back side ?
CharlesTX
05-26-2018 07:14:22
 Re: Super C clutch won’t disengage in reply to keeter84, 05-25-2018 17:04:14
The lock nut is under the adjuster bolt head. Look at the other fingers to see where they are adjusted to use as a guide, you will need the lock nut to keep the adjustment.
