Negative ground but with a generator???
Alan in VA
02-19-2007 13:22:14
I have new-to-me nice bright "H." It has a 6v battery with definitely the negative cable going to ground and the positive to the starter button and then to the starter. The coil says 6v and the neg from the coil goes to the distributor. The tractor has a generator. I thought, in my very limited knowledge, that if it had a generator, that it would have a positive ground system. What am I missing? Thanks for all your help. You fellows are great.
Alan
Nat 2
02-19-2007 16:52:35
 Re: Negative ground but with a generator??? in reply to Alan in VA, 02-19-2007 13:22:14
"Stock" is positive ground, but the system could be wired up either way with very little modification.
CNKS
02-19-2007 14:24:57
If your voltage regulator has stamped on it "6 volt positive ground", somewhere, I believe underneath, the contacts will burn faster, otherwise it makes no difference.
old
02-19-2007 13:32:07
Came from the factory with + ground but a lot of gennys will work either way if polarized that way
