450LP Head Cracked - Looking for Replacement
Marty K
03-01-2007 08:35:38
What I was hoping would be a "gaskets and seals" restoration on my 450LP has turned into a (364586) head that is cracked in cylinders 2 and 3 down to the valve guides. I suspect the engine froze long before I bought the tractor (it has a heavy block repair right behind the carb) and over time, the coolant eroded the crack along the wall of the water jacket and combustion chamber causing the metal there to be very thin (according to the engine guy I've got working on the repair).
Has the supply of potential good, used replacement LP heads pretty much dried up? I can't afford to pay $1,000 for a replacement. Am I relegated to having the engine guy fix mine?
the Unforgiven
03-01-2007 14:41:12
 Re: 450LP Head Cracked - Looking for Replacement in reply to Marty K, 03-01-2007 08:35:38
You may be able to go with a set of high-dome pistons and a shaved gas head to get the compression back up for the price of an lp head unless you happen to fall into one. Probably guys on the pulling forum that could tell you what CR you can get out of pistons and a gas head.
RustyFarmall
03-01-2007 12:10:54
You will not find a useable 450 LP head for under $1,000, so you need to fix the one you have, or convert the tractor to run on gasoline. A used gasoline head would be less costly.
