544D - light out!
Dave from MN
03-01-2007 17:21:05
Alright, need to do some snow moving tonight (if there is a let up) and I can not get my lights to come on, The fuse is good. Is there anything I can check easy without tearing off panels, in the dash, is the switch in these Ih's common to stay open , even when switch to on?? Othewr wise I can wait till daylight,
Bruce Wa.
03-02-2007 14:44:51
 Re: 544D - light out! in reply to Dave from MN, 03-01-2007 17:21:05
I find on any brand of tractor that I have the switch goes bad. They don't stay open,but rather over time, the spade prong where the power wire goes on gets rusty and breaks off. I think when they get old there gets a little resistance on the connection and then they get hot which makes them rust faster. I can show you 2 IH switches like you are talking about, a JD, and an A-C one. Same problem with all three. The old ones with screw type terminals can be tightened and don't give any trouble.
Janicholson
03-02-2007 09:57:55
If you really need the lights, run a jumper (with a 20 amp fuse in it) from the non-ground side of the battery or the bat side of the starter solenoid, to the back of one of the lights. Bingo. JimN
Fromjb2
03-01-2007 18:30:50
Hi Dave, check the grounds. Sometimes there will only be one ground in the circuit. Had an 81 Olds once and when you tuned on right directional signal, right high beam would flash with signal lights. Only one ground point for all lights on right front and it was corroded.
Good Luck
JimB
Allan In NE
03-01-2007 17:32:52
Fuse, light switch and lights.
I've seen some of 'em with that fuse wired to the ignition switch tho.
Who knows this far down the road? Could have been re-wired a dozen times by now. :>)
Allan
