Order Farmall Cub Parts Online
Farmall Cub hunting after overhaul
J. Klein Rot
03-04-2007 09:22:25
Hi,
I have completly rebuild the engine of my farmall cub new bearings new pistons new valves crankshaft reground, carburator rebuild new coil and points in the magneto. But when i started the engine yesterday, it starts quikly, it is hunting. How do i adjust the little spring in front of the governer, and how to adjustd the caburator.
Bus Driver
03-04-2007 12:06:23
 Re: Farmall Cub hunting after overhaul in reply to J. Klein Rot, 03-04-2007 09:22:25
The high speed jet is not adjustable. But it can be cleaned. It is the brass 3/8" hex on the side of the carburetor. Do not enlarge nor alter the tiny hole in the end of the jet.
Clean with smooth wire and compressed air. Hunting or searching often is caused by a lean mixture.
