Head gasket sealent
Andy A H M
03-04-2007 16:54:50
Hi I am 16 years old and I am restoring a Farmall H for a FFA project and I am getting ready to put the head back on and I was wondering if I needed some kind of a sealent on the gasket or if the gasket itself is good enough. I have asked some friends about this but I was looking for more advice. thank you
old
03-04-2007 19:16:00
 Re: Head gasket sealent in reply to Andy A H M, 03-04-2007 16:54:50
Copper coat is made just for that and will help spread out the heat so the head will seal down as it should. Also after it is warmed up don't forget to retorque the head
georgeky
03-04-2007 18:48:14
Alluminum spray paint on each side will also work just as well. Allow to dry to touch before installing. I learned this from my old FFA advisor.
CNKS
03-04-2007 17:08:25
I used copper coat on a Super H head gasket 3 years ago, no leaks.
Janicholson
03-04-2007 17:02:29
I use a covering single coat of CopperCoat brand spray sealer on my head gaskets. (unless the directions that come with it indicate not to, or require a different sealant. Follow the directions, Good luck with a great project, JimN
Andy A H M
03-04-2007 17:12:30
 Re: Head gasket sealent in reply to Janicholson, 03-04-2007 17:02:29
A friend said to use the same sealent. My gasket set did not have any instructions. Thank you for your reply
Owen Aaland
03-04-2007 18:53:56
 Re: Head gasket sealent in reply to Andy A H M, 03-04-2007 17:12:30
If your gasket is metal on both sides and looks like it has a coat of varnish on it, that coating is the sealant. It requires heat for the sealant to work so the engine needs to be run for the sealant to seal. As long as the block are clean and flat it will do a good job. If you have cracks or pits then some additional sealant in those areas may be necesary.
