'41MD value
red56turbo
03-05-2007 18:01:30
Just wondering a value of a '41 MD with original bosch pump and single fuel filter. Runs good on gas and switches to diesel. Probably needs some injector or pump work. Sheet metal good, fenders, rears 35% old check mark tread. Only down side is a rod has been through block. PO put a plate over the hole, drilled and tapped and bolted plate on. Might sell and wanting to know value. Any ideas? Thanks.
md41
03-10-2007 06:39:31
 Re: '41MD value in reply to red56turbo, 03-05-2007 18:01:30
what area of country u in i would be intrested in it if u are not
Jim Broughton
03-05-2007 19:09:35
Red Turbo; That plate shouldn't hurt performance, but it might be a "talking point" to a buyer. Heck, I put a plate on an old F-30 Farmall back in the early fifties, and it's still running !! As long as the crank and journal are good she'll run good as ever. Out here in Oregon, that tractor would bring a minimum of $1000.00 in fair to decent shape, running good.A lot depends on appearance, condition, and implements , if any. Good luck on er ! Jim B.
