504 torque amp.
makin'hay
03-11-2007 11:51:30
hopped on my 504 ind. started snow blowing, pulled back T/A and nothing happened. does anyone know if they go bad that quick? no slipping or anything, just no change when engaged. does an IT manual have good reference to a 504 T/A ? thanks
TomH in PA
03-11-2007 14:48:21
 Re: 504 torque amp. in reply to makin'hay, 03-11-2007 11:51:30
Look over the linkage. Could be something came apart or broke.
Hugh MacKay
03-11-2007 13:14:56
When was the last time TA and main clutch were adjusted to specs in IH operator's manual? I think it calls for this every 6 months or 500 hours of operation.
D Slater
03-11-2007 13:12:08
If no speed change when you pull lever back the T/A clutch is not disengaging for some reason. Also a outside chance the planet gears locked up for some reason,but I doubt thats it.
makin'hay
03-11-2007 18:09:20
 Re: 504 torque amp. in reply to D Slater, 03-11-2007 13:12:08
i could not find any linkage out of whack, but that does not mean none are broke. i will check specs and adjust clutch and T/A. it just seemed to have gone out when it was sitting in the shed. one day it worked and the next it didnt. ran out of time now though. looks like i know what im doing next weekend. THANKS !!!!
D Slater
03-11-2007 19:34:37
 Re: 504 torque amp. in reply to makin'hay, 03-11-2007 18:09:20
One other thing,if the T/A clutch is not disengaging when you push clutch to shift gears you will get hang up or hard to take out of gear, more so if on a grade and tractor tries to roll a different dirrection than gear dirrection. Do you have this problem?
makin'hay
03-12-2007 17:12:27
 Re: 504 torque amp. in reply to D Slater, 03-11-2007 19:34:37
now that you mention it, i sure do. i guess i did not notice it because its been happening for a while now.
