LOCKED TRANSMISSION SUPER M
CHIEFEAVES
03-16-2007 14:16:54
IS IT POSSIBLE TO UNLOCK TRANSMISSION WITHOUT TAKING THE TOP COVER OFF? GOT OFF TO CLOSE GATE AND LOCKED WHEN I TRIED TO START AGAIN.
CHIEFEAVES
03-18-2007 05:55:13
 Re: LOCKED TRANSMISSION SUPER M in reply to CHIEFEAVES, 03-16-2007 14:16:54
A BIG THANKS TO ALL OF YOU. DID WHAT YOU SUGGESTED AND TOOK LESS THAN A MINUTE.
John M
03-16-2007 17:58:41
Just to add to what others said, If its on a hill, chock the rear whells before attemping to line up the shift rails. I have only had one to do that to me , and even on the slightest hill I couldnt get them frred up. Chocked the bqack wheel, pushed in the clutch to take off the pressure and with 20 seconds I had them lined back up.
Nebraska Cowman
03-16-2007 17:16:42
It is possable to get it back without taking the lever out if you know what your doing and hold you mouth just right. Do it with a big screwdriver a few times you will catch on. Or else tou will get sick of it and build up the shifter. third party image
Roger Mills
03-16-2007 16:44:45
When u get the shifter out look at the end that goes into the shift rails-it is probably worn and so might the rails. For now you can get along by holding the shifter down when you shift and feeling for the detents. Common problem.
glennster
03-16-2007 14:31:22
yup, at the base of the shifter there is a cap on each side, you need to drive the cap in to pop the other side off, you will see a pin inside, drive the pin out, the shifter will lift out, look inside, you will see the shift rails, go in with a screwdriver and line them back up, that will put every thing back in neutral, drop shifter back in, good to go!!!!! !
