6v batteries?
Mike CA
03-18-2007 21:49:01
I think I'm going to buy a 6v battery with me to chekc out this '48 H to see if it will turn over with it. If I'm going to buy one, I might as well buy the one I'm going to keep and use. Someone suggested a "dry cell" battery is good for a tractor because they are vibration proof, and won't leak and mess up the battery box. I'd like to hear some opinions on what I should get, and where I can find them.
Thanks!
El Toro
03-19-2007 13:18:49
 Re: 6v batteries? in reply to Mike CA, 03-18-2007 21:49:01
I'm inclined to agree with Wardner. You usually don't buy the new furniture until the house is built. Hal
Wardner
03-19-2007 12:58:25
Mike,
Lets get real for a minute.
You just got rid of one derelict and you are about to look at another. You are setting a bad precedent. If the next tractor is sllightly better, perhaps your strategy will be like that guy who, after fifteen trades, turned a paperclip into a house. Good luck on that.
Right now you don't need a battery. If the tractor is unmodified, it will have a magneto. Pull the tractor in fourth or fifth gear. If the tires won't air up, then you are buying metal by the pound. $150 per ton. Even in California, a gallon of gas is cheaper than a fancy battery. What are you going to do with a 6V battery if you find a trashed trans/axle, a seized engine, a frozen clutch, a radiator that leaks faster than you can fill it, and so on?
Chances are this tractor is not one of those "It ran when I parked it deals." If it were, the owner whould have it running. Pulling it at ten mph will tell you most of what you need to know. Save your money for the decals you are anxious to buy and spend the rest on a nice dinner for your wife. She is going to need some attention when she sees what you have drug home.
Hugh MacKay
03-19-2007 13:51:27
 Re: 6v batteries? in reply to Wardner, 03-19-2007 12:58:25
Wardner: I'm torn between saying, "Save your energy" and "Amen".
Wardner
03-19-2007 14:11:49
 Re: 6v batteries? in reply to Hugh MacKay, 03-19-2007 13:51:27
You're right, Hugh. I should save my energy and sanity.
I've been thinking, though. What if Mike bought some F-14 decals and pasted them on one of his Navy jets? That might satisfy his need to acquire a tractor and, at the same time, save him alot of money.
How many plows could a F-14 pull?
Hugh MacKay
03-19-2007 14:23:13
 Re: 6v batteries? in reply to Wardner, 03-19-2007 14:11:49
Wardner: Great idea.
gene bender
03-20-2007 05:15:19
 Re: 6v batteries? in reply to Hugh MacKay, 03-19-2007 14:23:13
Boys this guy is getting more off base all the time was wondering about the exhaust manifold other day.
HENRY E NC
03-19-2007 08:25:06
There are two types of dry cell batteries. One is a glass mat battery (Optima and others) and the ssecond is gel cells. The diffence being that the electrolyte in a gel cell is exactly that, a gel and that prevents the formation of stuff at the bottom of the cell taht shorts out regular batteries. The Glass mat battery now used exclusively by the armed forces (so I am told) is made of glass cloth wrapped aroun the post and then joined at the top. Both are extremely tough and can sit disacharged for a long time witout damage, I have used both with great success. Had gel cells for 12 years in my boat (8 of them) with no battery problems. Changed to glass mat after that and no problems. Some gel cells need a specific charge voltage to (13.9) last a long time but glass mat are not that picky. Henry
Roger Mills
03-19-2007 07:14:18
Round here there is a place called Battery +, its a commerciaol battery shop, check yellow pages or big yellow on web. All sizes all shapes. They got me a 6 V Gel with group 1 rating. But--posts are different--they use a bolt through the cable end. Not a problem I used a cable that has hole at both ends. They ordered the cables too, proper size holes. Use 0 or 00 is better, 1 is too small.
Dave S.
03-19-2007 06:08:46
Are you refering to a gell battery? If you are they are expensive and if they become discharged can be hard to charge with a normal battery charger. Gell batteries do well under rough conditions and are non-hazardous,non-corrosive and can be mounted in other than upright position.
Do not know if they are made in 6V.
Nat 2
03-19-2007 05:27:41
I think you might be thinking of a sealed battery, not a "dry cell." Dry cell batteries are like the ones you put in the old lanterns.
Optima is about the only sealed 6V that I am aware of. Most "big box" auto parts stores only stock Group 1 6V batteries, which are correct for an H. Local parts stores that are Interstate or Exide dealers can get you pretty much anything you want. Don't discount your friendly neighborhood CaseIH dealer, as they stock "tractor" batteries.
gene bender
03-19-2007 04:39:16
Be sure to have new 1ga cables and a battery that has at least 700 cranking amps.
K-Mo
03-19-2007 04:33:36
Ask for a Group 1 battery.
K-Mo
Mike CA
03-18-2007 22:48:31
What are the dimensions of the battery box?
City-Boy McCoy
03-20-2007 15:41:29
 Re: 6v batteries? in reply to Mike CA, 03-18-2007 22:48:31
I don't know the dimensions off hand, but if you will get a group 1 battery, it will be the correct size. mike
Bob
03-18-2007 22:21:28
AFAIk OPTIMA still has 6-Volt units.
