IH 935 Paint Code PPG
Norvin Johnson
03-25-2007 16:16:21
Does anyone know the PPG paint code in the Omni or MAE line for IH 935 off white? Your help is appreciated,thanks1 N.J.
sammy the RED
03-25-2007 20:15:46
 Re: IH 935 Paint Code PPG in reply to Norvin Johnson, 03-25-2007 16:16:21
The IH-935 is too new for the 856.
You should be useing IH-901 White.
CNKS
03-25-2007 19:22:42
I am not familiar with the IH white code for the 856 -- it may be 901, (PPG 8665), not 935, perhaps someone on this forum will say for sure. If not, as I mentioned on the paint forum, you might find the answer on the RPM forum -- ask for Cliff Neubauer.--The current dealers are usually not familiar with the old paint codes.
El Toro
03-25-2007 17:31:59
They only list 2 PPG's paint codes for IH white. Hal
IH-902 code 90592
IH-935 code 91607
CNKS
03-25-2007 19:10:55
 Re: IH 935 Paint Code PPG in reply to El Toro, 03-25-2007 17:31:59
901 is 8665, but he doesn't want that.
Norvin Johnson
03-25-2007 18:36:50
the 91607 number only works in the concept line which is a very expensive line. Guess we'll have to spray some out of a can from CIH and match it. Thanks anyway!
El Toro
03-26-2007 06:02:23
 Re: IH 935 Paint Code PPG in reply to Norvin Johnson, 03-25-2007 18:36:50
You may be able to get the 91607 in Dupont's Centari acrylic enamel that may be a little cheaper. I paid $29.00 for a quart of Omni's Farmall red. Then you need to add the hardener and thinner. I still liked the results. Hal
