How to check Super A oil level
Kurt in Va Beac
03-27-2007 09:02:47
Hey all, I just got a '53 Super A and can't seem to find the dip stick to check the oil. How do you check it? thanks!
A. Bohemian
03-27-2007 11:03:01
 Re: How to check Super A oil level in reply to Kurt in Va Beach, 03-27-2007 09:02:47
Don't forget to bring a can to catch the dripping oil in! I save mine, and every few months I have enough for bicycle chains, door hinges, and other non-critical applications.
Kurt in Va Beach
03-28-2007 05:17:56
 Re: How to check Super A oil level in reply to A. Bohemian, 03-27-2007 11:03:01
Thanks for the help all! I kinda wondered if that was what they were for. thanks again!!
georgeky
03-27-2007 09:23:21
Kurt there is no dip stick. Look on the left side of the oil pan, there will be two pet cocks one sits a little higher than the other. Open the top one and add oil until it starts running out and it is full. From then on as long as oil will run out of the lower cock it has enough in it. When no oil runs from lower cock it is a quart low.
Cue P.
03-27-2007 09:21:23
There are two petcocks on the side of the oil pan...an upper level and a lower. Loosen it up until some oil drips out (drips, not gushes). The oil level should be between the two.
