Measuring RPM on M
DenT
03-31-2007 05:13:22
In IT manual when checking governor ,it tells what idle and wide open RPM's should be. Is this measured at the PTO shaft with a hand held tach. or somewhere else on the motor? Thanks in advance. By the way this is on a 48 M. Just wanted to see if the settings were close. Tractor is running fine.
randy hall
03-31-2007 13:02:58
 Re: Measuring RPM on M in reply to DenT, 03-31-2007 05:13:22
yes a hand held tach would work good on the pto. hi idle on the pto is 606 for an m.
Andrew Z
03-31-2007 10:47:46
I use a Tach made by Stihl (the saw company). all you have to do is put it up to a plug wire and it tells you the RPMs. very easy and works great.
Andrew
rpdRobert
04-06-2007 16:46:11
 Re: Measuring RPM on M in reply to Andrew Z , 03-31-2007 10:47:46
Where did you find the Stihl Tester?
Janicholson
03-31-2007 13:18:27
They are great. Make sure that it is set for a four stroke or it will read rpmX2 JimN
Andrew Z
03-31-2007 14:02:11
 Re: Measuring RPM on M in reply to Janicholson, 03-31-2007 13:18:27
Yup. they will read 2 stroke and 4 and 1, 2, and 4 clylinder engines you can use them for 6 and 8 but have to devide the number up.
Andrew
RustyFarmall
03-31-2007 07:30:37
One of those handheld tachs on the PTO shaft will give a pretty good indication. You want the tach to read a minimum of 540 rpms. When I first got my 1940 M, it ran good, but I though it seemed rather slow. A tach on the pto shaft confirmed my suspicions, not even close to 540. A little tweaking in the governor got me to where I wanted to be. If I remeber right, it now reads about 560 rpms.
Janicholson
03-31-2007 06:14:55
four ways
Use a simple (some what old fashoned) Tach Dwell meter on the distributor primary wire (goes to the points)and ground. Reads rpm directly, cost about 20-30$.
Use a strobe shaft tach (probably rentable, or more expensive), but very useful for "no connection necessary" speed monitoring. They work on any moving mechanism or shaft.
Use a shaft tach on the belt pulley or PTO and do the math to determine engine speed. Still some fair cost, or rent.
JimN
Roger Mills
03-31-2007 06:05:27
If the manual shows from around 1200 to 1800 RPM, as it probably does, then it is the engine.
