Thermostat ....Torque Values
Tom Windsor
04-04-2007 20:41:31
On the H engine, would you abandon the thermostat? The thing runs real cold anyway.
Torque Values...what is the torque value on a 9/16 socket sized (3/8 Bolt?) Course Thread.
El Toro
04-05-2007 07:03:15
 Re: Thermostat ....Torque Values in reply to Tom Windsor, 04-04-2007 20:41:31
A good way to sludge up an engine is to not allow it to get up to operating temperature. It needs to be worked under load to get up to operating temperature. Your car or truck needs this too. Just running a mile or so to do a few errands and then shutting off the engine won't allow the engine to get hot. I would install a new thermostat too. You just need to snug those bolts on the thermostat housing with a 3/8 drive ratchet. Hal
PS: I bet if you hook that tractor to a 2-bottom plow and do some plowing the temp will come up.
williamf
04-05-2007 02:27:09
If it runs cold it's more likely that the thermostat needs replacing rather than abandoning. When I first got my H it never warmed up without covering the radiator; once I replaced the thermostat it warms up to normal operating temperature (160-180) quickly. I'm told that letting them run cold all the time is hard on the engine.
Thermostats, even brand new ones, can be stuck open.
Good luck, Wm
JayWalt
04-04-2007 22:52:53
I would run the thermostat.
NDS
04-04-2007 21:04:44
I would run thermostat.
Torque for 3/8 16 bolt Grade 2.. 16 dry 12 wet, Grade 5.. 30 dry 23 wet, Grade 8..45 dry 35 wet. At least that is what chart I checked says.
