Super C Fan Nut - washer
Salesweasel
04-08-2007 12:43:46
How thick is the washer behind the fan tightening nut to the bracket/water outlet? One I have is about 1/8" thick and is too thick to let belts line up correctly. I had been running without the washer, but had to change water pump and don't want to put wear on fan tightening nut.
Salesweasel
04-08-2007 18:04:51
 Re: Super C Fan Nut - washer in reply to Salesweasel, 04-08-2007 12:43:46
I measured mine and it is 5/64". I remember I tried to use it and the water pump belt was wearing (black flaking off) so I took the washer off. I now have a new water pump - this is how this question got started - hopefully it will align like your SC does. Thanks for comeback.
Keith-OR
04-08-2007 15:52:49
The stock one on the boy's SC is a little thicker than 1/8th. Awful hard to actually get in there to measure it. Everything lines up fine with this washer.HTH
Keith & Shawn
