I thing its a 424 IH
parlo
04-08-2007 16:47:10
I bought this tractor without side sheilds and I don't know what size it is. Can anybody out there help me? Thanks in advance
IH2444
04-09-2007 16:24:51
 Re: I thing its a 424 IH in reply to parlo, 04-08-2007 16:47:10
Looks like add on power steering to me.
Gary in Mozarks
04-08-2007 17:47:04
I also have a 424 like Bob's but mine doesn't have a precleaner and it has factory power steering so there isn't a steering shaft on the left side like Bob's. The muffler is underslung since its a utility. A little under 40 hp and a great little tractor. Rus rings around the 8N I replaced with it.
Bob Farrell
04-09-2007 05:14:36
 Re: I thing its a 424 IH in reply to Gary in Mozarks , 04-08-2007 17:47:04
Gary, as you may recall I have a 424 diesel, power steering, like yours. Mine does not have a air pre-cleaner. Were they factory or add on?
Gary in Mozarks
04-09-2007 06:44:46
 Re: I thing its a 424 IH in reply to Bob Farrell, 04-09-2007 05:14:36
I have no idea, I would guess that they were available for a dealer to add. I know very little about what is stock, other than the owners manual, as I bought 2 parts tractors, one with a spun bearing and one that had a bad head. I rebuilt the bottom end of the one with the bad head and used the head off the one with a spun bearing. One had 28 inch tires and one had 24 inch rims on it. Mine has a set of double remove valves on the left side of the seat but the hardware for the levers, under the seat is missing. I never have found a parts tractor or any place that has those levers. I also need a grill but have never found one. I made a nose cap by cutting a 460 cap and removing a portion from the center. I will probably make a grill out of expanded metal and sheet steel, unless I find one. whatever the case, its a great little tractor.
Bob
04-08-2007 17:19:51
third party image
Model/serial # tag is on the side of the tractor; ahead of your right foot.
Here's my 424; a 1965 diesel.
parlo
04-08-2007 17:38:07
 Re: I thing its a 424 IH in reply to Bob, 04-08-2007 17:19:51
how can you tell with the serial # what model it is
georgeky
04-08-2007 19:27:11
 Re: I thing its a 424 IH in reply to parlo, 04-08-2007 17:38:07
By looking at the serial number list. Look to left of page and click on serial numbers. It is under Research & Info.
Bob
04-08-2007 17:59:03
The plate SHOULD have both the model # AND the serial #.
sam the man
04-08-2007 17:09:37
is the air filter behind the muffler or in front
parlo
04-08-2007 17:14:18
 Re: I thing its a 424 IH in reply to sam the man, 04-08-2007 17:09:37
its behind the muffler
sam the man
04-08-2007 17:17:00
 Re: I thing its a 424 IH in reply to parlo, 04-08-2007 17:14:18
I have 424 & the intake is behind the muffler
