A Sand Blaster A Spray Gun
City-Boy McCoy
04-17-2007 05:06:48
Howdy, boys. I spent yesterday with a sand blaster and a spray gun. While I am no stranger to either, I never would have guessed I would use neary all of a 100 lb sack of sand on ONE Super A rear rim - and it wasn't a terrible looking rim to begin with! What a lesson there, to wit: Buy more than 200# of sand. But, the final results are satisfying - at least to me. mike
Shaggy
04-17-2007 07:17:36
 Re: A Sand Blaster A Spray Gun in reply to City-Boy McCoy, 04-17-2007 05:06:48
You need to work in a Sand plant or know somebody that does and the sand is FREE! I work at one and we throw away more sand in a day than you would ever use to blast a tractor.
The last time a blasted I used a little finer sand and it seemed to work a little better.
toolz
04-17-2007 07:00:48
This may be something you already know, but the body shops in my area use sand called "black beauty" that's made from lava rock, so I'm told. They say they use 1/3 as much since it's so agressive. Leaves a real nice finish, too. It costs about $12 a bag, as opposed to $7 a bag for silica, but works so much better. It's sold here at the concrete plant.
Wardner
04-17-2007 10:32:07
 Re: A Sand Blaster A Spray Gun in reply to toolz, 04-17-2007 07:00:48
Black Beauty is but one brand name for coal slag. Reed Minerals Inc distributes that brand after it comes out of coal fired electric generating plants. They used to have more than a dozen plants accross the country.
Black beauty can be effecting when stripping heavy corrosion or coatings due to its angular profile. Sand is preferred when visibilty is not a concern. It weighs more, impacts harder, and gets you to "white metal" faster when comparing screen size to screen size.
No cheap blasting media has a 3x advantage over another media in the same screen size. I used to be in the business and purchased over 300 tons (unbagged) per year.
eDDIEpETTY
04-17-2007 05:34:22
..ditto Rusty"s remarks. As the sand wears down, the dust will blow away. I use a large shop fan to help the dust along. Use a large funnel with a screenwire mess over the top to filter debris.
When I sandblasted my A"s rear bands, much to my surprise the following was uncovered stenciled on the inside of each band....."Mfg. by Firestone Tire & Rubber Co. 12-6-44".
City-Boy McCoy
04-17-2007 05:40:25
 Re: A Sand Blaster A Spray Gun in reply to eDDIEpETTY, 04-17-2007 05:34:22
My rims were stamped "Goodyear" on the band area under the rust, and the date (I don't recall) was contempory with the date of my tractor. Interesting. I wonder who else supplied rims to IH in those days? mike
RustyFarmall
04-17-2007 05:24:10
Get you one of those cheap plastic tarps, lay it out on the ground, and do your blasting on top of it. Then you can sweep up the sand, sift it through a window screen, and re-use it. Eventually the sand will all turn to dust, but until that happens it can be recycled many times.
City-Boy McCoy
04-17-2007 05:44:58
 Re: A Sand Blaster A Spray Gun in reply to RustyFarmall, 04-17-2007 05:24:10
Thanks, Rusty; Great idea. What a fool I was for not thinking of that. Well, I've got the other SA to do, as well as the SH, so I'll sure use the tarp method with them. mike
RustyFarmall
04-17-2007 06:30:50
 Re: A Sand Blaster A Spray Gun in reply to City-Boy McCoy, 04-17-2007 05:44:58
Don't feel too bad, I lost about 100# of sand before I figured it out. Even with the tarp, the wind will still blow some of it away and then it is gone.
SuperA-Tx
04-17-2007 06:21:03
I used a small hand held sand blasting gun and reused my sand several times filtering it thru an old coffee/tea strainer I got at the grocery store. Worked OK but you can tell after a couple uses the sand doesnt cut as good as it did when new.
But what I wanted to say was that after doing all my tractor I learned a lesson. My cultivator parts and draw bar I took to a professional and he did in ten minutes what would have taken me over a week to do. I think it cost about $130 to get them blasted and primed but it was the best money I spent.
This summer I am taking my rear rims off and having them redone because I aint happy with the results I have now. I didnt take the time to do it right the first time since I was in a hurry to get the tires mounted and to my store where I could work on the tractor. I think I'll redo the fenders at the same time. You can bet I wont be doing the sand blasting tho. Ill let a pro do it with his big gun. Do the thin metal parts and small stuff if you want but the big heavy stuff take to a pro and save you some time.
Oven cleaner helps cut a lot of old paint off saving a lot of time too.
Did my sand blasting in a 40 X 60 metal building with cement floor and when I got done there was sand dust on everything. Had to move everything out and wash it off and then get the water hose in the building and wash it out. Was a BIG mess!
