DT 361
jpsepp
04-17-2007 15:21:38
What is the correct valve setting for the intake and exaust valves?
Tan67
04-17-2007 18:18:51
 Re: DT 361 in reply to jpsepp, 04-17-2007 15:21:38
what kinda turbo charger you runnin on the jewl???
Tan67
04-17-2007 18:14:39
Ok heres the setting but make sure the engine is hot when you do the check up because i do not have the setting for the cold engine "sorry" I imagen it would be 2 or 3 thousents less by geussing. or if you could find the setting for a cold one maybe would help.
Intake-.013-thousents(HOT)
Exhaust-.025-thousents(HOT)
I geuss you have a 1206? if so, i warn you the valve cover can be a A..... .... to get off if you dont do it just right if the tank is still on. Tan67
