Farmall A Series Cylinder Compression Ratings
dunniteowl
04-23-2007 17:29:54
Hey everyone,
dunniteowl here again and I have gotten the "A" model I have straightened out as far as the cylinder head and torqueing goes. I am getting spark, fuel, air and compression, though I wonder if my compression levels are high enough to combust.
So, does anyone have the specs or the skinny on what the nominal compression values ought to be?
Currently, Bettty's compression values are as follows:
Cyl 1: 72 pounds
Cyl 2: 60 pounds
Cyl 3: 61 pounds
Cyl 4: 71 pounds
do these numbers sound about right to anyone or no-one at all? I have a maintenance manual (bought online through your suggestions) and it doesn't have any compression specs in it that I could find.
Thanks all for any information and assistance you can provide...
dunniteowl
El Toro
04-24-2007 04:32:15
 Re: Farmall A Series Cylinder Compression Ratings in reply to dunniteowl, 04-23-2007 17:29:54
Squirt some engine oil into each cylinder and crank over the engine before squirting and gasoline into plug holes. Don't mess up the plug
wires firing order mark them with a piece of tape.
The rotor turns CW so the wires should be in this order1-3-4-2 with No1 near 1 o'clock. Hal
Janicholson
04-23-2007 17:47:10
It will run with that compression. It may even be pretty much OK if it is a Dual Fuel tractor with low compression head. Let us help with other details.
Put an oilcan squirt of gasoline in each cylinder, then try to start it.
If No Go, put #1 at tdc and check the direction of the rotor. Should point to #1 plug wire. Other help is here, tell us what you have done. JimN
dunniteowl
04-23-2007 20:12:48
 Re: Farmall A Series Cylinder Compression Ratings in reply to Janicholson, 04-23-2007 17:47:10
Great advice, Janicholson! I will keep updating this as I go along. This comes from an original post called: Help Need the (Farmall) A Team! Where I reported that I had an overheat issue, found a blown head gasket, then couldn't get the compression done well, found I didn't install gasket correctly (no sealing compound-- oops!) and then couldn't seem to get compression in the cylinders to match too well. I ended up starting all over with the gasket (removed it, scraped off compound, lightly sanded head and block surfaces, reinstalled and re-torqued in 5 pound increments from 10 pounds up to the new standard of 80 with the new gaskets.)
During that time there were a few times I tried to check compression without the rocker arm assembly installed. I know, stupid thing to do, but ultimately, I figured it couldn't really hurt as the pistons don't go to the top of the cylinder sleeve and the valves don't depress anywhere near the top of the cylinder wall/sleeve. Also I realize the cam-shaft is mated to the crank from below and not having the rocker arm assembly in place on top should not have any net negative effect. I am sure this could be wrong, but it logically seems sound from the perspective of construction.
I do believe, however, that this could seriously affect the timing and again admit I am happy to be wrong about that.
I am going to try the gas in the cylinder trick and if that doesn't do it, I will indeed be making sure the timing is set the way you suggest. From there I am sure new information will be coming.
Once again, thanks for the tips and I will be posting new stuff as soon as I have daylight, dry ground and no other distractions (I have no garage or actual workspace for my tractor and I just have to 'rough' it where she currently is in the yard -- which is growing ever higher as I attempt to satisfy the conditions that will get her to operate again.)
A. Bohemian
04-24-2007 06:49:48
 An Alternative View in reply to dunniteowl, 04-23-2007 20:12:48
(Hal and Jim, don"t be afraid to contradict me. I will defer to your more extensive experience.)
Dunnite, isn"t this the tractor that was spitting oil out the stack after you perhaps poured transmission fluid into the oil by mistake?
Yes, this tractor will run with those readings. Someone (I forget whom) is fond of pointing out that they had a flat-head Ford V-8 that was winning races with 40 lbs. in each cylinder!
But, in that famous instance, the compression was low but the differnce between cylinders was not great.
I did the math, and came up with a seventeen percent difference between the highest and the lowest compression readings. That may be only marginally acceptable.
The "wet" readings may be somewhat better. Compression testers are not completely accurate. And, a compression test itself is not the final authority.
Nevertheless, it is my personal belief that if the gasket is now correctly installed, the valve train is functioning correctly, the plugs are all seated correctly, etc., and these are accurate readings, you are headed for a rebuild sooner or later.
Also, you"ve named this tractor, which leads me to believe you are fond of it. If you don"t already know, delaying a rebuild by continuing to run a worn engine can lead to more extensive and expensive damage.
Finally, there is a frustration factor. Again, the tractor will run with those readings. It may be quite hard to start, though.
And, will it pull well enough to run a mower? You won"t know until you get it running and try; and my personal belief is that it will only pull well enough to cut thick or high grass if you make half a swath on each passage and stay in first or second gear. Very frustrating.
If the cash is available, consider plunking it down for a rebuild now. If not, start saving.
Hal? Jim?
Janicholson
04-24-2007 07:21:58
 Re: An Alternative View in reply to A. Bohemian, 04-24-2007 06:49:48
Getting it running is something we all agree on. If it is tuned correctly, and proves itself worn (Knocking, blue smoke, missing, weak kneed, or overheats) I agree with your analysis 100% JimN
