h charging
henryv1111
04-26-2007 07:23:03
Is there a diagram that show how the wires should be conntected from a 3 brush gen with 2 position co to the amm meter and 4 position light/HL switch?
Thank you
Bob M
04-26-2007 07:42:16
 Re: h charging in reply to henryv1111, 04-26-2007 07:23:03
You should find what you need in the link below.
Note: With your new setup there will be no connection to the field control resistor on the light switch. Also switch positions "L" and "H" will become simply two alternate "off" positions for the lights.
henryv1111
04-28-2007 05:59:19
 Re: h charging in reply to Bob M, 04-26-2007 07:42:16
Bob M
thank you for the info. I got it charging 20A but only shows 6.7 volts at the battery terminal. I get 7 volts at the A terminal at the Cut out. What kind of voltage should I be getting. Could the wire from the A meter to the cut out be to small.
