Newly painted 806
Tan67
04-26-2007 19:41:59
hey guys, just got the 806 painted this evening, as a matter of fact the paint is still wet right now, now all i need is to paint the dash and sheet matel and put the newly painted wheeles . but man is it beautiful, i need some decal placement help thow, Any suggestoins please???
Tn67
04-27-2007 10:55:06
 Re: Newly painted 806 in reply to Tan67, 04-26-2007 19:41:59
hey guys thyanks for all your tips they are very helpful!! ive never herd of putting it on when the paint is taky, but the clear coat is a heck of an idea. Im goin to pill the tape off saturday and paint the dash and mount the tires. but thanks for the tip!!!!!
El Toro
04-27-2007 03:39:24
You should post a picture of your tractor. Hal
the tractor vet
04-26-2007 20:02:22
Put a bunch of decals on the 706 -806 tractors as i have painted more then my fair share.. And the factory decal kit ain't cheap for all that ya get in the pack. The big becareful one goes on the kick panel on the bottom of the dash along with the park lock decal and the oil change one goes on the oil filter the hyd filter goes on the tear drop hyd. filter cover one caution one goes on the back on the tin plate by the pto handel and the lite switch one goes below the lite switch. the one for the air filter well that one goes on the cover . I do not have any close up pictures of the ones i have done up .
Patrick Martin
04-27-2007 03:59:28
 Re: Newly painted 806 in reply to the tractor vet, 04-26-2007 20:02:22
i like putting the decals onwhen the paint is stuill tacky. That way the paint will help the sticker adhere better. Maybe that's not the case but I've always done it and never had a sticker to come off yet. Also I usually spray a little clear coat over the sticker as well to seal it.
the tractor vet
04-27-2007 06:56:45
 Re: Newly painted 806 in reply to Patrick Martin, 04-27-2007 03:59:28
Never done it that way the paint is always dry when we put them on and i have never used clear coat on a tractor . when we install them we just take some windsheild washer spray and wet down the area and stick the decal on and squeege the water out this removes any air bubbels and with a soft cloth wipe dry . And since i am cheap every tractor that i have painted has always been in the case i h 2150 enamel .
the tractor vet
04-27-2007 06:47:07
JayWalt
04-27-2007 04:57:47
good ideas there Patrick.!! not sure about applying the decals to tacky paint, but the clear coat idea is definitley a good one.
Patrick Martin
04-30-2007 03:03:28
 Re: Newly painted 806 in reply to JayWalt, 04-27-2007 04:57:47
Yep, that's how I do them on my cars when I have a decal to install. It seals the decal and you can take advantage of the UV inhibitors in the clear coat.
As for application over tacky paint that's just how I do it. It must work since I've never had one peel yet.
