450 cast hubs and JD-14rims
High Octane
05-03-2007 06:23:45
Will John Deere rims (late double bevel) rims fit on 450 hubs? I have several sets of these rims, 14 inch, ust wondering if I can make em work. thank you.
RustyFarmall
05-03-2007 06:59:12
 Re: 450 cast hubs and JD-14rims in reply to High Octane, 05-03-2007 06:23:45
Should work just fine, but they won't properly fit until that yellow paint has been removed.
High Octane
05-03-2007 08:00:30
 Re: 450 cast hubs and JD-14rims in reply to RustyFarmall, 05-03-2007 06:59:12
Thanks Rusty! Oh yes, gonna be silver in color. The rim selection is wide, from 14 up to a 20 inch rim that can go right on the hub. I picked up a few sets of duals at a sale a while back, and I needed a set of rims for our SM. Ended up with a set of cast hubs off a 450, so Im glad I can put two and two together. While I got ya on the line,, was it you, that said you had some IH carbs that needed repaired. (bored out that went thru the side)???? Its been a while back for the post,, if it was you, shoot me a email, I wanna talk to you bout repair options. Thanks again! ChadS
