1466 dash lights
brian t from oh
05-05-2007 19:54:18
The dash ligts don"t work on my 1466. Gauges work fine,headlights work also. Any ideas on what to check to fix
Allan In NE
05-06-2007 06:00:47
 Re: 1466 dash lights in reply to brian t from ohio, 05-05-2007 19:54:18
Brian,
You're probably gonna find that every bulb in 'er is burned out or the metal socket has a bad ground.
That circuit runs from the light switch, out to the junction block under the right side rear cowl panel and then from there on out to each individual light socket.
Trace 'er with your test light.
Allan
Brownie450
05-06-2007 03:40:52
Check for a wire that has jiggled loose from the light switch. Unlikely that all bulbs burned out all at once, except for a voltage surge.
Jossette
05-05-2007 20:13:48
fuses ?
