Farmall T-20 Restoration
Adam H.
05-14-2007 08:40:08
I'm working on a T-20 crawler and having problems with the engine...When the engine is not under load it wants to run rich and rough. It acts like it just needs a simple carb adjustment, but all the adjustments I try to make doesn't help. When it is idling the jets can be shut completely and it will continue to run for a little while before it starts to stall. I rebuilt the carb, but the kit I was able to get was only gaskets and a float needle. Does anyone have suggestions of what to try or where I could get a complete carb kit? Any help would be welcome.
Peavy Tx
05-14-2007 19:21:38
 Re: Farmall T-20 Restoration in reply to Adam H., 05-14-2007 08:40:08
I had the same idleing problem on my 36 F 20. Rebuilt carb and same problem. Bought professionaly rebuilt carb and same problem again. Your posts reinforce my conclusion that there is no problem. Thats just how they run. I just need to keep the plow in the ground.
Adam H.
05-15-2007 04:10:18
 Re: Farmall T-20 Restoration in reply to Peavy Tx, 05-14-2007 19:21:38
When yours is running rough does it push black smoke?
It just doesn't feel right to have it running like that, but I guess i'll just keep working with it and see what happens. Thanks for the reply.
Eric in MN
05-14-2007 09:25:36
yes i have a farmall f-20 that shouyld have the same motor and carb in it and mine acts the same way when going down the road it will miss but as soon as i get a load under her then she runs like a top maybe thats haw there sopossed to be
