farmall c-firing sequence.
patrick Cliffor
05-14-2007 10:37:13
Hey, I replaced the plugs, distributor cap, rotor, condenser and points on my farmall c. However I did not check the sequence when I took off the wires. Would anyone be able to help me out? I have ordered a manual, but it won'be here for a few days. Thanks.
FrankD
07-21-2007 13:25:56
 Re: farmall firing sequence. in reply to patrick Clifford, 05-14-2007 10:37:13
Is the order of the pistons 1 - 2 - 3 - 4 from radiator to steering wheel?
I can"t get 3 & 4 to fire. 1 & 2 are great. I even swapped the wires and the plugs t no avail.
Thanks
bnowen
05-14-2007 21:59:58
 Re: farmall c-firing sequence. in reply to patrick Clifford, 05-14-2007 10:37:13
My original owners manual pictures the distributor order as going from number one at top right looking at the top of the dist. and then 3,4, and 2 on the top left. As usual, I am sticking with the manual.
gene bender
05-14-2007 19:18:01
Firing order is rite on the block with big letters rite below #2 and 3 plug
El Toro
05-14-2007 13:59:30
I give up just remember the firing order is 1-3-4-2. Hal
El Toro
05-14-2007 13:56:07
Let me try that again. Hal
2-1
4-3
old
05-14-2007 12:22:14
A little hint for doing that in the future. NEVER pull all the plug wires at a time. Replace them one at a time then you almost can't get the fireing order wrong
El Toro
05-14-2007 10:51:49
They should be in this firing order with No1 near the radiator. 1-3-4-2
PS: When the rotor rotates CW in this order. Hal
2-1
4-3
Janicholson
05-14-2007 13:00:06
 Re: farmall c-firing sequence. in reply to El Toro, 05-14-2007 10:51:49
from rear view looking forward at dist
2-1
4-3
Order is 1342 from front
Janicholson
05-14-2007 13:02:50
 Re: farmall c-firing sequence. in reply to Janicholson, 05-14-2007 13:00:06
The system is hashing our carage returns on our letters The first two nipples get cylinders 2-1
They are on the top, The second two get 4-3 put in them. they are on the bottom. JimN
