Whats a Belcrank?
Clarkbug
05-20-2007 16:36:18
Hello All.
I was looking through eBay today, and someone has a belcrank that fits a Farmall M.
So, Im curious.
Whats a belcrank? What would it do? Im just curious....
Thanks!
georgeky
05-20-2007 17:14:43
 Re: Whats a Belcrank? in reply to Clarkbug, 05-20-2007 16:36:18
I looked and it is for the throttle. It mounts under the hood with a linkage going from throttle lever to it, and one going from it to the governor.
Clarkbug
05-20-2007 17:40:25
 Re: Whats a Belcrank? in reply to georgeky, 05-20-2007 17:14:43
Thanks for the quick replies guys.
So it goes from the throttle to the govenor, and its a funky thing that could be L shaped... (I get what you mean, it makes sense to me now)
But why would I use it for anything? I dont think the M I have now has one of these, does it?
georgeky
05-20-2007 17:59:05
 Re: Whats a Belcrank? in reply to Clarkbug, 05-20-2007 17:40:25
Of course it does. It is right above the valve cover. Without it you couldn't give your tractor any gas.
Clarkbug
05-20-2007 18:58:09
 Re: Whats a Belcrank? in reply to georgeky, 05-20-2007 17:59:05
Ahh, OK.
I just havent seen it on my tractor yet, which would explain why it seemed strange to me.
Sorry for the ignorance, Ill just check it out once I can actually check out my tractor again. This whole different states thing is probably the source of 50% of my questions....
Thanks for putting up with them all!
Janicholson
05-20-2007 17:01:30
A bellcrank is any lever system that has a single pivot point, and two levers sticking out from it. Usually they are not across from oneanother. They change the direction of linear motion. Some ora mounted on a shaft or tube and also displace the force along the shank to offset the force. A capital L with a pivot at the bottom left would be an example of the shape. radiator shutter linkage, throttle linkage, and other places have them on an M JimN
Al L. in Wisc.
05-21-2007 11:16:04
 Re: Whats a Belcrank? in reply to Janicholson, 05-20-2007 17:01:30
I sure am glad you asked that Clarkbug. I had heard the term before but it didn"t apply to anything I had, or so I thought! Just goes to prove to me once again... "I can learn sumptin" new every day, even if I don"t want ta."
