Farmall / IHC 706 ??
rustin
05-26-2007 10:00:53
I am looking at purchasing a 706 with a loader. I was told it is an IHC 1965 model, but I am not so sure if that is correct or not? It has a serial #7716-S-Y. Can someone please varify this for me? I am also wanting some input (good & bad) on this model of tractor before I make a decision to buy. I would be using it for moving round bales of hay, snow removal, little dirt/manure hauling, mowing, post-hole digging. Thanks for the help.
Iowafarmer45
05-26-2007 17:15:24
 Re: Farmall / IHC 706 ?? in reply to rustin, 05-26-2007 10:00:53
The 706 is a good tractor. I owned one and sold it to my father-in-law in 1983 and he still uses it in South Texas to mow and pull brush on his ranch. The shifting mechanize is the week point. The linkage gets a lot of play in it and makes it difficult to go from High range to reverse because of all the slop. It is fixable and not that expensive to fix. They fixed this problem on the next model the 756. There were two diferent diesels put into the 706 (also a gas option). The first years used the D282, which is the same as the Farmall 560 engine ran at a higher rpm to get more Horse Power. The later year used a German diesel that had a few more cubic inches and more HP. Both are good engines but the D282 used glow plugs and has starting problems unless you keep all the glow plugs working. Most people liked the German diesel better until they needed an overhaul. The German diesel cost about twice as much to overhaul. These tractors came with two point or three point rear attachments mounting. If it is two point you will need adapters to use three point equipment.
IaGary
05-26-2007 12:40:30
That serial # makes it a 64,but condition is more important than what year it is.
Check out the gear shifting. Seems that is the most common problem on the 06 series.
Gary
CNKS
05-26-2007 12:39:01
Early 1964. S means it has a TA, and if it has a PTO it is 540 rpm. Y means low and reverse attachment. 706 was/is a good tractor, but I have never owned one.
steveormary
05-26-2007 19:20:02
 Re: Farmall / IHC 706 ?? in reply to CNKS, 05-26-2007 12:39:01
I had a 706 with ger. engine which I liked very well. It would pull a4-16 semi-mount plow(fast hitch) or a 14 ft.swather in L4. About 5mph.
steveormary
