'68 IH 424
BlakeTN
05-29-2007 18:34:14
Hello all. I just purchased a new to me '68 424 with a bush hog and loader that I get to install and bring home this weekend. I have to replace the hoses on the loader, first.
What all do I need to know about this tractor? I have a '48 8N back at my parent's place, and my day job is a mechanic, so I'm not totally lost when it comes to tractors or repairs.
The PTO stage of what the gentleman called a two stage clutch is out. Is there a relatively simple adjustment for this, or does the tractor have to be split and the clutch replaced? If that's the case, I may just deal with it for a while.
Are there any key things that I really need to know about this tractor? What size plow or bushhog could it handle in Tennessee clay?
Thanks!
BlakeTN
05-30-2007 19:41:21
 Re: '68 IH 424 in reply to BlakeTN, 05-29-2007 18:34:14
I appreciate the comments, guys. I really dont have the time to be splitting the tractor in half right now, but maybe this winter I'll get around to it. Right now, I need the tractor to maintain 48 acres of property. I'm really glad to hear it's twice the tractor the old N was, because that little thing was a hoss. I wanted to get another N for this property, but I couldnt pass up the deal on the IH. I've always been a red fan for some reason.
The tractor has a 5' King Kutter bushhog that's almost brand new, but I have a slightly used 6' Bushhog brand mower sitting down at the barn. For what I need to do, it sound like the 424 will be able to handle the 6' just fine, unless I get into some really thick stuff.
The tractor does have power steering, which I figured was basically a necessity with the loader on the front. The left tie rod is a bit loose, but it really isnt that bad. The valve cover leaks and it black smokes a bit when it's cold and you really load it, but I'm not terribly worried. With the amount I plan on using it, it should run quite a while.
I'm really excited about it. I stopped by and took the bad hoses off of the loader tonight, and will have replacements made tommorrow, then install them and drive it home. I really want to see how it handles in high range. I'll try to get pictures up this weekend.
Gary in Mozarks
05-30-2007 05:20:00
First off, you now have twice the tractor that 8N ever was, even though its the same size. I pray it has power steering, they were a bear without it. I agree with George and JJ I have used ours with a 7 ft brush hog but it is really working. It purrs along with a 5 ft. You will probably have to split the trator and replace the clutch to fix it, but its not as bad as it seems if you have a chain fall and a floor jack. Get at least an IT manual for it. Send us some pictures
J.J. from Afton
05-29-2007 20:45:31
That size of mower should be no challenge for a 424. I drove one at the county fairgrounds with mower on it that was either 90" or 96" that we used to cut the back 15 and front 5 acres of weeds about once every other month.
georgeky
05-29-2007 20:13:46
The PTO clutch is likely out. I split mine to fix it. It will handle 2x14 plow with ease, or even 2x16. And should be OK with 6 or 7 foot bushhog.
