IH504 Steering
Stu K
05-31-2007 09:56:57
I have a 504 that the steering is intermittent, I guess would be the best word. When it's cold always, and sometimes when it warm it just stops working and squeals like mad. The engine lugs down and sounds like it's really working.
IT Manual seems to lead to the pressure relief valve being bad. Anyone ever had this problem??
Thanks,
Stu K
pcs
06-02-2007 06:34:02
 Re: IH504 Steering in reply to Stu K, 05-31-2007 09:56:57
mine is a row cropper my brother has a 606 utility and had the same problem i think a hyd oil change and filter helped
Stu K
06-04-2007 05:05:40
 Re: IH504 Steering in reply to pcs, 06-02-2007 06:34:02
Yeah, I tried that first. The filter was dirty, and the oil had a little water in it, but it didn't help the steering.
Sounds like I have a pretty unique problem.
Stu K.
pcs
05-31-2007 10:12:27
i have a 504 doing the same thing...i need to replace a steering shaft u joint it seems to bind up at that spot sometimes
Stu K
06-01-2007 09:34:39
 Re: IH504 Steering in reply to pcs, 05-31-2007 10:12:27
Thanks for the input, but mine does not have any u-joints that i can find. This is a utility model. Comes straight out of the steering shaft and into the steering motor. Couple of pipes running down to a distribution block and then tubing/hoses running up to the front end.
I had the tractor jacked up so the fron wheels did not have any weight on them, and still the same thing.
Stu K.
