Order Farmall Cub Parts Online
Farmall Cub fan belt pulley
Farmall Freak
06-04-2007 14:28:39
On my 1950 Cub the fan belt pulley was originally filled. I have been told to run grease in it, but I am just not too sure about that. Also If I run oil inside it what type should I run and how far do I fill it, thanks.
Denny ('60 Lo-Boy)
06-04-2007 15:37:11
 Re: Farmall Cub fan belt pulley in reply to Farmall Freak, 06-04-2007 14:28:39
Turn the pulley so the filler screw is at the 9 o'clock position (or 3 o'clock depending which way you are facing). Remove the screw or plug and fill with motor oil until it runs out. Then turn the hole down to the bottom and let the excess drain out. Replace the screw. It's a strange system and uses a slinger type mechanism.
