2150
VAJerry
06-13-2007 10:45:29
What tip to spray IH 2150? First time experence.
the tractor vet
06-13-2007 14:23:37
 Re: 2150 in reply to VAJerry, 06-13-2007 10:45:29
well the way i spray it is to fill the cup about 2/3rds full add a splash of Dupont 77 S hardner and a splash of Case I H thinner mix well let set for a few min. and put on the mask and at about 38-40 lbs air pressure at the gun lay down vary light coats let flash and lay down the next let flash and so on ususaly lay down 6 light coats the first three you can still see thru it sorta like sparyen iodine on the fourth coat is when ya can lay down a littel heavier to start building color. Now that is my way as i am no real painter but it will come out real good with no runs no hits and no errors.
Lawmar
06-13-2007 11:08:38
I don't knwo for sure what tip you want but a good tip is that you need to put hardner with it to get it to set up in a decent time frame.
